https://pcpartpicker.com/user/asg27/saved/#view=FWNQZL
Might have gone a little overkill, but after playing on a laptop whose only function was to assist me in completing school work, I decided to go all out. I hope to never again get sub 20 frames while running minimal settings. Also, I wished to create a system I won't have to upgrade for a long time. I'm looking forward to playing games such as Rise of the Tomb Raider and Metal Gear Solid TPP at 90-100+ frames on maxed settings. Another goal of mine was to create a small form factor case as I am currently a high school senior and in the coming year when I move off to college a smaller sized pc may be a life saver. I know I have missed out on a hard drive, but in this micro atx case there is only one 3.5 inch drive cage so I'm going to survive off the 500 gbs for now until I can comfortable afford a 3 or 4 tb hard drive that should last me a long time. Any advice on cpu vs gpu performance for the price would be greatly appreciated. I can't afford both a 1080 ti and an i7 8700k, but after research I have concluded that the i5 8600k should get me almost the same performance at a much reduced cost. Thanks again for all your feedback and I look forward to reading any and all comments.
https://linustechtips.com/topic/955641-my-first-build/
14 minutes ago, asg27 said:
I can't afford both a 1080 ti and an i7 8700k, but after research I have concluded that the i5 8600k should get me almost the same performance at a a much reduced cost. Thanks again for all your feedback and I look forward to reading any and all comments.
Go Ryzen then ;)
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/955641-my-first-build/#findComment-11606549
