simultaneous rgb led flashlight
Solved by W-L,
5 minutes ago, Momenaut said:I actually saw that one and under the modes: 4. tri ribbon looked like it may be what I want but I wasn't sure. I was inspired by this video and wanted the same effect from a flashlight:
For that kind of effect you would still need separate lights far apart as they have in place since RGB LED's tend to combine them into white lights decently well. This is also the same effect you get from RGB LED strips when you try to produce white light giving a dirty or hazy look of the Red Green and Blue separating a small amount.
