Please Help NOOB BUILDING PC
Go to solution Solved by seon123,
Why did you buy a PSU that there are no reviews for? DC-DC regulated, but a crappy fan, a 3 year warranty and a 30°C temperature rating, so it's probably not very good.
Should probably run fine.
Please Help! I’m trying to build A computer and I have a EVGA 500BR PSU, (EVGA 500 BR 100-BR-0500-K1 500W ATX12V / EPS12V SLI CrossFire 80 PLUS BRONZE Certified Non-Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=17-438-145)
and I’m hoping it can handle all the items I throw in it! But I need to verify it’ll work!
I’m going to use a Ryzen 5 1600 with its stock cooler, I’m going to use TimeTec 8x2GB DDR4, I’m going to use a PNY GTX 770 2GB, a OSCOO SSD, (the unknown brand items should not be too power consuming), the motherboard is a AB350M Pro4, and a couple of RGB fans and RGB strips, please REPLY TO HELP ME! Thanks :D!
BTW not overclocking, at least not right now! Lol
https://linustechtips.com/topic/955182-please-help-noob-building-pc/
Yeah, 500 watts should be enough.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
 I bought it because it was on sale for $20, and it’s made by EVGA! I looked around and found out the 770 needs a 12V singular rail with a rating of 42, my PSU has a 12V singular rail with a rating of 41.7 so it should be good!
The CX450/M also goes for sale for a similar price, and those are known to be good.
EVGA doesn't make any PSUs. And they're quite capable of selling crappy PSUs with an EVGA sticker on them, just like any other company. Their crappy PSUs, off the top of my head are the N1, W1, B1, B3, G1, NEX G and NEX B.
There's more to a PSU than how many amps it has on the 12V rail(s). And having multiple rails is preferred to a single rail. Just like having several fuses in a house is preferred to having a single fuse.
^^^ I run a Ryzen 7 2700X and 980 Ti off a 550W PSU (albeit a much more high quality one, the EVGA G3) just fine, you shouldn't have any issues where wattage is concerned.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
So my PSU should be able to function with the Ryzen 1600 and the GTX 770
I’ve used their psu and their reliable! But I just want to make sure it’ll function, it will never be under full stress but it’ll have to handle games like GTA V!
EVGA, as he said, doesn't "make" their own PSUs. They have OEMs for that and they have price points for everything. Your 20 dollar unit is so far removed from a 1600 T2 you're on the wrong zipcode.
That unit is not very good and I would not put it in a system with a dGPU. It has zero professional reviews, is very recent, has a short warranty, and is of questionable quality given its price point.
Wattage wise you should be fine, but:
Basically reliability wise it's pretty questionable, $40 or so is usually the cheapest you can get a decent PSU unless there's a sale on something like the Corsair CXM series or 2017 and newer CX series.
Mouse: EVGA X17
Well the PSU Acosta $50-$60 new, it’s that I got mine on sale Is all
The psu costs a lot more without my discount that got it to $20
More expensive doesn't always denote quality though.
Mouse: EVGA X17
There's probably a reason a 500W power supply was on sale for 20 dollars. The PSU isn't even listed on newegg anymore. They wanted that gone fast.
Almost all PSUs have a 12v rail btw :D
Take a look at this and rank it yourself:
Please quote me or @ me in your response so I get a notification.        I really really really really like small text.
Occupation: Gamer | Hours: 24/7 Full-Time | Hourly Pay: 0 | Benefits: Chick Magnet
FINISHED BUILD - VIEW PROFILE
If you say I'm not always right, but I am, I will say I am right.
rekt
