So the issues im having is the Black Screen when you use "window capture". But basically Id like to start streaming  mobile games.  Now im also aware of the fix you can do to get it to work. However my problem is I have the AMD Ryzen 1500X and it does not support integrated graphics. So I was wondering if theres another way to either spook your computer into thinking it has them? Or if theres a plugin for OBS that does the same thing as window capture but doesnt black screen when you use it? Or if you know another way to fix it for AMD users? Any help would be great!
O/S: win10
GPU: GTX 1060 6GB
CPU: AMD ryzen 1500X
Ram: 8gbs Hyper X Fury DDR4
https://linustechtips.com/topic/955058-need-help-from-obs-users-on-win10/
O/S: win10
GPU: GTX 1060 6GB
For Window Capture, you need to set it to an open Window that you want to record. By default it is black and set to LockApp.exe but you need to select the app window you want to record.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
See I am setting it to a window i'd like to record,  but even with a selected window. It still only shows a black screen and wont record what's on the window.
Are you running the latest Nvidia drivers?
Yes. The fix im aware of is to switch obs in the "Nvidia Control Panel" "3d management" from "GPU" global settings to "internal graphics". Because at leadt to my knowledge I guess its a known issue. Im not sure why that fixes it but it seems to be the most comon fix. However like i stated before my CPU doesnt have internal graphics. :/ Other then that all my drivers are current.
