Yes you can use a modified router with Yamon installed.
http://usage-monitoring.com/index.php
https://linustechtips.com/topic/955045-internet-speed/#findComment-11600844
Many router softwares have that built in already. My ASUS router it does.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/955045-internet-speed/#findComment-11600864
Just now, TheTwist said:
Ah yeah the one here is more of a Netgear firewall
Gotcha, may be that Yamon software will work then
https://linustechtips.com/topic/955045-internet-speed/#findComment-11600877
1 hour ago, TheTwist said:
Is there one for an active directory maybe?
Do you even have a domain server ?
As per others it depends on the router.  Something like Mikrotik can give you live graphs and per-flow live throughput statistics between specific source/destinations.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/955045-internet-speed/#findComment-11601940
Only your router knows what speed each device is doing on the Internet, so ultimately any solution has to run there.
https://linustechtips.com/topic/955045-internet-speed/#findComment-11603141
Yeah there i do have a domain server
Ah looks like mine doesnt have a function :(
https://linustechtips.com/topic/955045-internet-speed/#findComment-11604188
AFAIK very few consumer routers do unless you install custom firmware.
https://linustechtips.com/topic/955045-internet-speed/#findComment-11604216
Custom firmware is nice, but you REALLY have to choose the router carefully and get something much faster than you think you need as it typically doesn't support the hardware acceleration features that stock firmware uses to handle faster broadband.
Its why I gave up on it and just built a PC with pfSense on it.
https://linustechtips.com/topic/955045-internet-speed/#findComment-11604672
