Improving airflow and cable management
Solved by WoodenMarker,
Everything seems fine.
If you want to clean up cables, you can hide the AIO ribbon cables behind the tubing and secure them to the tubing with zipties. Be sure to not over tighten them and pinch the tubing.
The pump cable would be better hidden being plugged into the top fan header and the top fan cable can be hidden along side of the left motherboard heatsink.
I'd personally bend the pcie power cable up over the graphics card as opposed to under but to each their own.
