Hey i am trying to help my friend change case, on his pc, he started before i arrived so i dont know where all the wires go, at the moment some of or problems are:  the litle pin thingy on the bottom right side on the mother board, as seen pn the pic tjere are for different thing witch goes on the pin, and we have looked in the case and can only find the 'power sw' (we asume its the power button) and the 'led+/-' (we asume are pled), we cant find reset and hdled. And our other problem is that we have one cable witch says sata power and another with tbe same connector, witch we dont see fit anywhere, where do these go.
Motherboard: Asrock Z170 Pro4S
https://linustechtips.com/topic/954483-please-help/
SATA Power goes to your SATA Drives. They do not go on your motherboard.
Also, does your case even come with a HDD activity LED and a Restart switch? Some cases are cheaping out an excluding those features.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/954483-please-help/#findComment-11595580
