(I am running a Intel DZ77BH-55k, 8GB Corsair Vengeance 1333 MHz ram, a Gigabyte GTX 770 4GB, an i7 3770k, and a h100i )
Hi,
I woke up this morning, and as usual, I turned on my computer. Usually when I turn it on, the fans spin at top speed for a couple of seconds, then they die down. This time, they did not. After a almost 30 seconds of top speed fan running, the computer turned itself of and the process repeated. So, I turned the computer off and opened up the side of the case. Now it will not get past the bios screen.
Here are some symptoms:
1. The light on the water block turns red. (I always thought it was white before, but I am not sure)
2. The fans spin at top speed for 5-15 seconds, die down, and repeat the process.
3. The motherboard (Intel DZ77BH-55k) is hung on a post code of 92.
If you need any more information, I will be able to take pictures, video, etc.
Thanks in advance,
smithaveryb
My Rig: | i7-3770k @4.9 GHz | h100i | Intel DZ77BH-55k Mobo | 16GB 1600 MHz Vengeance Ram | GTX 770 4GB x2 (SLI) | Acer 21.5" 1080p Monitors x3 | 1TB WD Black x2 (In Raid 0) | 256GB SSD | Quickfire TK Blue | Razer Deathadder 2013|
Surfing it up in Huntington Beach, USA. Find me on Steam (my username is /r/buildapc).
https://linustechtips.com/topic/95448-computer-will-not-boot-symptoms-inside/
Yes.
Try the keyboard in a different port. If that doesn't work try a different keyboard.
Build Log: Monochrome
CPU: Intel Core i5-4670K | Motherboard: Gigabyte GA-Z87MX-D3H | Graphics Card: Asus HD 7970 DirectCU II | RAM: Corsair Vengeance Pro 8GB | PSU: Corsair CXM 600 | Storage: OCZ Vertex 4 128GB,2 Seagate Baracuda 3TB | Case: Corsair 350D Window
I would try a CMOS reset to see if it fixes it and did you try pressing the button on the back called Back To BIOS to see if you can access the bios that way?https://communities.intel.com/thread/29795
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
I tried a different kb in a different port and it still doesn't work.
unplug all sata drives and see if the system will post
remove all ram sticks and try one at a time in all slots
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
