So I was brought this old computer with a pentium 4 545 and they told me that it does not give any signal . So i changed the cpu to a pentium 4 845 , and now it gives signal , but it boots into Windows xp , and a couple seconds after it shuts off . The first time , it reached the welcome screen , but now every time I try , it goes out at the same time . The psu is brand new btw.
https://linustechtips.com/topic/952435-old-pc-help/
The 845 is a Pentium D, not a P4 (essentially two glued P4 dies, though). I'm suspecting a cooling problem. The Pentium D consumes significantly more power than a single P4. Did you clean the cooler and did you reapply thermal paste?
edit: p4 545 doesn't exist.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/952435-old-pc-help/#findComment-11577249
1 minute ago, NelizMastr said:
The 845 is a Pentium D, not a P4 (essentially two glued P4 dies, though). I'm suspecting a cooling problem. The Pentium D consumes significantly more power than a single P4 like the 545. Did you clean the cooler and did you reapply thermal paste?
Yes I did , Had to buy new cooling paste . I am using the stock cooler
https://linustechtips.com/topic/952435-old-pc-help/#findComment-11577252
Yea its not exactly a 545 , the cpu say its a pentium 4 541and it is for the plga775 socket.
https://linustechtips.com/topic/952435-old-pc-help/#findComment-11577255
And also I don't remember if the cpu is exactly an 845 , but I am pretty sure it is.
https://linustechtips.com/topic/952435-old-pc-help/#findComment-11577258
49 minutes ago, boredatwork said:
Intel stock ?
RIP
It's either an 840 or a 945. The 840 is a 130W CPU, where the P4 is only 84 so it might very well be a cooling issue.
https://linustechtips.com/topic/952435-old-pc-help/#findComment-11577348
