Hello,
I'm starting to work for my A-Levels soon and I need help deciding which laptop to get. I want a laptop that can do my school work, but when I get home some gaming (which wont be heavily intensive like GTA, I usually play games like Overwatch). My budget is somewhere around £1,500 England.
I would prefer to have a laptop with 512GB SSD, but which ever seems most suited.
Thank you for any help. :)
https://linustechtips.com/topic/952248-help-deciding-laptop/
Take a look at something like the GS65
https://linustechtips.com/topic/952248-help-deciding-laptop/#findComment-11575490
7 minutes ago, Flawizz said:
Perhaps the HP Pavilion 17-ab360nd  with 16gigs of ram. Sadly a 200gb ssd. Has a 1050ti which runs overwatch very well :) and an i7 7700hq. Has an ips panel and is 17.3 inches which is the biggest format for a laptop if im not mistaken.
This looks about good for me :P
Thank you for your suggestion :)
https://linustechtips.com/topic/952248-help-deciding-laptop/#findComment-11575534
For your price range you should be able to get a way better system than that.
Take a look at dells G7 lineup.
https://linustechtips.com/topic/952248-help-deciding-laptop/#findComment-11575539
Preferred display size, weight and battery life? Any links of online stores?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/952248-help-deciding-laptop/#findComment-11576306
