Hi,
Sorry if this is the wrong section to post this.
So I've recently built a computer and pretty much every single component is rgb.
I bought all of it 4pin non addressable so that it would sync with my asus aura but I find myself a bit disappointed in options I have, especially as I only have 2 ports on my mobo, even static colors are limited to 1 of 2 colors for all the components.
Can anyone recommend a 3rd party controller that will allow me to, at the very least, set each component to a different colour? Different effects would be my choice if possible.
I dont care how expensive it is, or how complicated to set up, as long as I dont have to do any actual coding myself.
Sorry for the essay and thanks for any help!
https://linustechtips.com/topic/952039-4pin-rgb-controller/
google RGB LED controller and take any you like, they are not connected to the computer but this is the most usable option.
your options for colors and effects are still very limited simply because the LED´s are not addressable so you will always have one strip in one color.
https://linustechtips.com/topic/952039-4pin-rgb-controller/#findComment-11573426
Yes but can you recommend one that has features such as breathing effects, etc
More important one that has multiple ports and different outputs for each.
My Google searches aren't finding me anything like that, if they actually exist.
Edited by Dartagnan28
Clarity
https://linustechtips.com/topic/952039-4pin-rgb-controller/#findComment-11573490
Are you looking for a remote or software solution cause if you want to sync color modes and styles your only option is to go through their software. They do have their API available for third parties to create different lighting modes and styles.
https://linustechtips.com/topic/952039-4pin-rgb-controller/#findComment-11580443
