$1000 Build + Questions
Solved by GoldenLag,
Region makes it a bit diffcult.
If you want tl go to ryzen i recommend waiting untill next gen. The current CPU listed is plenty and should work well with the Rx480
Next gen Ryzen will be in April next year
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
