Recently more and more often ive been realizing that my brother gets me kicked from r6 siege when hes on his phone. Not sure why this has changed from before when it never even happened. My ping goes to 1000+ and it gets me kicked from any online match i play even if i host the match. My router doenst have any built in QOS settings and i cant buy any software so if anyone knows of a free way to fix this then please help cause i cant play anything if anyone else is on the network.
https://linustechtips.com/topic/951901-wifi-users-have-priority-over-ethernet/
@Shmoofle I dont think its gonna be as easy as a piece of software, u need someway of prioritzing traffic on the router which is usually done through its software.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
yeah im using a shitty at uverse router which is pretty much a bare bones router
Change the Router settings either by going to your Router IP-Address or AT&Ts login website
I think your brother is trolling you
2 minutes ago, Shmoofle said:
Wish i could but i dont really have any money to spend atm or anytime soon and when i do it wont be on a new router
Any old WiFi routers laying around? any of your family members have one laying around?
EDIT: CONTACT YOUR ISP (AT&T)
Question, I know that extensions of the network will still cause the same lag but will a new router have the same affect if its on the same network while i let the provided one be used for my brother or will the net work still have the "shared" affects that ive been having.
What speed package do you have?  A lot of people have problems when a phone or similar connects and starts syncing shit to the cloud
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
It depends what is causing the issue.  At the very least it should bypass anything in the main router that might somehow be prioritising WiFi as the second router is effectively just another wired client so far as the main router is concerned, including any WiFi clients connected to it.
In my opinion its generally a good idea to keep WiFi on a separate device anyway as heavy use can slow down Internet traffic due to taxing the CPU, plus you get the benefit of being able to position it more central in the house for optimum reception and more easily turn it off if you want to cut off all WiFi entirely.
Gonna try to do that when i can get the money thanks for your help.
@ShmoofleChristmas is coming up, ask Santa for one ;-)
Internet Speed.....
What kind of phone your brother has?  If he's using an iPhone, you can enable "Network Link Conditioner" on his phone and throttle his bandwidth.  See this post for instruction.  https://nshipster.com/network-link-conditioner/
Ideally, you want to have a wireless router or WiFi access point that allows you to set bandwidth limit per SSID channel but you said you are not planning to upgrade network equipment so you will need to look into software solution.
