hi all , new to the group. i have the following desk top and need help on changing the cpu to make it run faster.
it is an emachine, el 1850-01e has windows 10 , processor intel celeron 450 ,500 gig hard drive an 8 gig memory .
what cpu can i up grade to? power supply has 2 reading max 80 watts out and max 220 watts out put.
i guess you can tell i don't know a lot about this but have changed hardware in desk top before
thanks norman 55
https://linustechtips.com/topic/951267-cpu-upgrade-help/
nah, there are no CPU upgrades for this machine. Faster CPUs (in comparison that is, still very slow) either has higher rated power draw or higher FSB, both means they arent supported upgrades.
Desktop benching:
https://linustechtips.com/topic/951267-cpu-upgrade-help/#findComment-11566094
Build a new rig.
Thats not a system you should upgrade ..or can upgrade.
220 watt OEM psu, not somthing you shuld reuse and is totaly underpowered for newer morep oerfull hardware.
The CPu is form 2008 .. total end of life socket platform.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/951267-cpu-upgrade-help/#findComment-11566096
As said above, the money you spend on upgrading this system would be better spend on newer hardware.  Even something simple like a refurbished Dell/HP office PC which can be had for under $100 with a core2 duo or even a first gen i3/i5 core (if you look hard enough).
https://linustechtips.com/topic/951267-cpu-upgrade-help/#findComment-11566120
Scrap that system and find a new one, even if it is an old office-PC from Ebay that has an i5 2400 in it.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/951267-cpu-upgrade-help/#findComment-11566150
nothing says you have to get rid of it. keep it around for a backup system to muck around in, without having to worry if something doesn't work and you have to wipe it. use it to learn linux maybe, or set it up as a media pc in the livingroom? give it to the kids. or the neighbours' kids.
visit every shady website on the internet and click every suspicious link, and then take it to the local computer shop and ask if they can fix it without wiping out your "super important data" and then laugh as they burst into tears... lol
https://linustechtips.com/topic/951267-cpu-upgrade-help/#findComment-11566227
