I'm trying to build a new pc for $650 that will livestream videogames on twitch. I have already experimented with streaming and began to fall in love with it but I have way too many limitations with the pc I currently own. I've worked for a couple months raising money to purchase this new pc and during my free time I built a couple pcs on pcpartspicker.
View my setups: https://pcpartpicker.com/user/crocman132/saved/
Although these pcs are more than $650 I would like to shave off some of the unnecessary purchases in order to save extra case for other needs.
I have a spare HDD, don't add one.
If you can make a better pc, link it below please.
https://linustechtips.com/topic/951043-650-usd-budget-max/
What games are you streaming? You might benefit from having 16Gb of RAM.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11563931
get a cheaper 580 and use the money for a Pro4 mobo.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11564030
10 minutes ago, crocman132 said:
I'm streaming fps games such as Minecraft, Fortnite, Cs:go, etc.
You should be able to get away with a Ryzen 5 1600 for those, but for longevity I would still recommend Ryzen 7.
As well as 16Gb of RAM, you can barely multitask having Fortnite open with 8Gb.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568123
Is that even possible with a $650 budget? @Crunchy Dragon
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568146
You might have to make some cutbacks elsewhere.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568152
4 minutes ago, crocman132 said:
I already made the cutback of reusing a 1TB HDD so would this work? https://pcpartpicker.com/list/2cyx29@Crunchy Dragon
That should work.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568168
Just now, crocman132 said:
Will the Ryzen 5 and the 500 watt psu be enough?
Yeah, I run an overclocked Ryzen 5 1600 and an overclocked GTX 780 on a 550W PSU, no issues.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568209
I'm going to hope you're right because that means this build (https://pcpartpicker.com/list/2cyx29) is going to be my final decision.
https://linustechtips.com/topic/951043-650-usd-budget-max/#findComment-11568212
