Not sure if this is suppose to be in this category but how am I going to put the fans on the bottom? Case is an InWin 301, Motherboard is a Gigabyte AB350M Gaming 3. I’m trying to put the fans on the bottom for intake but the USB plug uses most of the space. Anyway I can fix this? See pictures
https://linustechtips.com/topic/950588-front-usb/
What's your case? Can't you put the fans at the side for intake?
You might have to bend the cable over the fans to make them fit. Based off the fan mounting holes, it's possible but it will be close.
Edited by Dissitesuxba11s
I can't read
https://linustechtips.com/topic/950588-front-usb/#findComment-11559928
Jesus thats a thicc cable.... Dont think so maby try and order a low profile fan ? that fan is 12MM ticc
https://www.amazon.com/Scythe-Slip-Stream-SY1212SL12H-120mm/dp/B002CYRROY/ref=sr_1_2?s=hi&ie=UTF8&qid=1532210985&sr=8-2&keywords=Scythe+Slip+Stream+Slim
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
https://linustechtips.com/topic/950588-front-usb/#findComment-11559934
I would try installing the fan first and the seeing if you can get the cable plugged in after.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/950588-front-usb/#findComment-11560011
