Need help making home server from old computer
1 minute ago, GrapeLesbian said:Performance for what exactly? Data transfer rates? Processor speeds for servers?
data transfer speeds
1 minute ago, GrapeLesbian said:In terms of transfer rates I would like it to be at least as fast as a USB 3 external drive, preferably much faster.
gigabit is about 1/5 of the speed of usb3, so your not getting those speeds unless your paying for 10gbe.
2 minutes ago, GrapeLesbian said:Really? What's the limitation for this? I use it just fine for my i7-7700HQ GTX1050 Ti Laptop, though it is starting to fill up.
What drive is it?
Its probably a nvme drive and that board can't boot from a nvme drive.
2 minutes ago, GrapeLesbian said:What's up with Motherboard RAID? Will look into Unraid
Motherboard raid is known for having issues and being a bad software raid solution.
If your on windows just use storage spaces, it will work much better here.
Unraid is a different linux distro that works well for home servers, but since you want windows, you not using it. You can run a windows vm on unraid if you want though.
