Hello! I want to make this as short and sweet as possible to waste as little of your time as possible.
I have been recently having problems with stuttering and just overall a not smooth experience in almost all of my games even though i have 60+ fps in each. I believe it has to do with my frame time with frames not being in sync from my gpu to my monitor. Vsync does fix the problem, but I experience extreme input lag which i find to be worse than the stuttering. I have tried using riva tuner to cap my fps to 60, but to no avail. I am wondering if their is another solution to this problem without having to either:
a) buy an expensive 144hz or gsync monitor
b) or just deal with the stuttering/ input lag
Any advice or links to other threads are greatly appreciated.
Their is also a possibility that it is a psu problem and that I don't have enough power to support my components. (I have a 500w power supply)
Specs:
CPU: i5-7500
GPU: GTX 1060 6gb
Ram: 8gb ddr4
HDD: 1TB toshiba DT01ACA100
SSD: Samsung 860 Evo, 500 gb
Thank you so much and once again, any and all help is greatly appreciated
Screenshot of my frame rate to Frame time:
*Vsync was enabled in this screenshot
I have also recently rolled back my drivers but from a suggestion but that did not seem to fix my problem.
https://linustechtips.com/topic/950469-frametime-and-stuttering-problems/
You could likely be thread limited for frametime delivery. (More Modern Games=HighFPS = HigherThreadLoads@4ThreadMax=Possible Bottleneck for Data delivery.
Faster IPC or more Threads required.
I'm thinking thread-bound because my i5 would do similar, and got sorted by adding threads (i7) without anything else changing.
/On a well balanced system, with near zero external software running in the background.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
2 minutes ago, BOBWARPATH said:
  Hide contents
older processor is your drag. 1060 is perfect. I have an i7 3820 and it drags down my frames too
thats the thing, my framerate is fine.I took that screenshot while playing league of legends, which I should have absolutely no problems running. My frames are 120+ during that game at max settings but my screen stutters and tears. Does not make sense that this problem is coming from my cpu but I am not the most proficient in software/hardware so i don't know
