Don't be scarred off by the anti sli police about to come ^^^.
Are you sure you have enough pci lanes left to use two cards? Are both showing up in device manager?
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
https://linustechtips.com/topic/950259-sli-help-pls/#findComment-11557484
Both cards show up I assume, cpu supports the lane requirements and you are on a compatible os.
If a clean install of drivers hasn't been done yet, id try to get another bridge. Though I doubt that's the issue with so little info.
https://linustechtips.com/topic/950259-sli-help-pls/#findComment-11558423
1. Troubleshoot the SLI bridge if you got a second one laying around
2. Troubleshoot the PCI-E slots. Remove one of the cards, then try and boot with one card only in both PCI-E slots.
3. Troubleshoot both graphics cards. Do the same as in (2) but with the other card.
4. Test the cards in a different system
5. Test different cards in your system
6. Nvidia tech support
7. Asus tech support
I have to ask, are you sure both cards are getting enough power?
Motherboard: Asus X570-E
CPU: 3900x 4.3GHZ
Memory: G.skill Trident GTZR 3200mhz cl14
GPU: AMD RX 570
SSD1: Corsair MP510 1TB
SSD2: Samsung MX500 500GB
PSU: Corsair AX860i Platinum
https://linustechtips.com/topic/950259-sli-help-pls/#findComment-11558471
