this is my first time building a PC and I have 7 RGB components to connect to my ASUS ROG STRIX Z370-E Gaming MOBO. It has 2 rgb headers that i can split with 3-way splitters but how do i connect to the third addressable header ? it only has 3 pins ?
the case is a h500p mesh, so thats 2x 200mm RGB fans.
I have a corsair H150i AIO cooler, thats another 3x 120mm RGB fans and the RGB block.
And im also adding an additional RGB fan for exhaust.
i want to run the whole thing with AURA sync as i have RGB RAM aswell as the mother board having RGB elements.
How do I do it ?
Also will I need a fan controller for all the fans ?
https://linustechtips.com/topic/950172-help-with-rgb/
How do I do it ?
Welcome to the Forums!
For the devices as long as they are all 4 pin RGB you can use the regular header with splitters, the 3 pin addressable is only compatible with addressabled based LED's and will not work with regular 4 pin analog connections. As for coolers like the Corsair AIO it cannot connect to the headers since they use their own dedicated control system.
https://linustechtips.com/topic/950172-help-with-rgb/#findComment-11557492
