Aside from getting someone to weld it shut (without creating more cracks), the only option I know of it getting a new case (or a used one from a yard or something)
Edit: it seems like you can get certain parts of the case, so maybe you can replace the cracked side instead of changing the whole thing
Some people also use JB weld, don't know if that's an actual fix or only a temporary measure
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548391
Its my first suzuki and this thing looks designed to fail. Ive seen people use Jb weld, but i only think to use it on really cheap stuff with virtually no stress on it.
Looks to be spreading too.
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548410
Did you talk to a shop about a potential fix? or how much it'll cost to get it fixed?
It's bound to spread after use; heating and cooling (running the bike then letting it cool off) will affect it
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548420
No i fix everything myself. Figured they would qoute me $750 for the case, mark it up, plus $80 an hour. Which is a lot of money for this specific machine.
Wont hurt to ask though, ill see what they say.
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548434
A new case, or welding it are the only good options here. Any weld shop worth their salt should be able to weld that up for you for one shop hour, probably between $75 and $150.
However, if you really do want to be cheap, you can JB weld it, but first remove the case and drill a hole at the end of the crack; this will reduce the stress concentration and stop the crack from spreading. After that make sure you clean the case as well as you possibly can, inside and out before applying JB weld.
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548547
2 hours ago, Kamjam21xx said:
So i noticed this crack on my ltz 400 and was curious what to do about it. All input welcomed. A new case is too expensive..
"mustie1" on youtube (great channel) fixed a crack on a ATV once, maybe there's something in the vid you can use:
https://www.youtube.com/watch?v=bFL1i7Q2kK4
JB Weld looks impressive in this video tough:
https://www.youtube.com/watch?v=aVLoJe3JbFI
Good luck.
https://linustechtips.com/topic/949248-cracked-crank-case-help/#findComment-11548855
