I now have a nice setup Define S case with 2x 140mm pull in the front and 1x 140mm push in the back 100% speed 24/7
Temps are nice and sweet on the big roomy side. Accept for the HDDs in the back compartment
I didn't pay notice to the temps in the old case but I'm now reaching 43c on the SSD idling in 40c (win disk)
3 regular HDDs at 40c-41c constant idle or not
Can I leave it? Can I do something to improve it? Tight squeeze at the back no fan hole in the side as the other side has
This chart got me a bit worried as I have spent good money to get good temps
Hard Disk Temperature
Less than 25°C: Too cold
25°C to 40°C: Ideal
41°C to 50°C: Acceptable
More than 50°C: Too hot
https://linustechtips.com/topic/948782-hot-hdds-in-define-s/
There's not really any airflow if they're not in a HDD cage in the front of the case like usual, so there's not much you can do. Around 40c is perfectly fine for a SSD or HDD, though. 50+ is where things get dicey.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/948782-hot-hdds-in-define-s/#findComment-11543673
