Case, fan, or thermal paste.
I have an antec sonota 3 case. With one 120 mm fan 79 cfm.
CPU i7 990x 3.4 GHz runs warm at 85C
Opening the side panel drop it be 6-11 C.
I am thinking of getting a 150 cfm fan to replace the back fan.
I am on the fence about the front fan because it is on the mobo ( vs front panel) side of the drives get.
With the CPU running 75c to 100 C I think maybe I get
https://linustechtips.com/topic/948731-case-fan-or-thermal-paste/
Welcome to the forums.
I would get all 3 actually.
Your old case has very restrictive airflow.
A good case fan from Noctua or beQuiet! would help a lot for front intake.
And of course if you haven't reapplied the paste in few years might as well swap it.
From the sounds of it, you would benefit the most from adding additional fans.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Yeah don't simply replace fans. Add fans.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I would switch to a newer case, and definitely replace the thermal paste with something like Thermal Grizzly Kryonaut:
https://www.amazon.com/Thermal-Grizzly-Kryonaut-Grease-Paste/dp/B011F7W3LU/ref=sr_1_1?ie=UTF8&qid=1531814518&sr=8-1&keywords=thermal+grizzly+kryonaut
Arctic MX-4 does the job also quite well.
1 hour ago, DNA3e8 said:
Stepping back and being a bit more pragmatic.
What temperature should I see? How do I find that out?
75C under load is good temp. 80C is acceptable, 85 hot and over 90C is time to do something. There are several software you can use to monitor temps. Like HWmonitor or MSI Afterburner.
And is the cooler big enough?
It is a cooler master Like the hyper T4 or hyper 212 but with the fan inset.
Yes, its fine. Your case isn't best, and I can say from experience that moving from older style case to modern can improve your temps by 7-10C. I would also consider trying how much re-pasting helps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
