How the hell is this algebra? This is discrete math.
A) first you must prove the relation is transitive, reflexive, and symnetric. If you don't know what these are... Well, you better study because you are missing the fundamentals.
B) only do this if the relations is indeed an equivalent relation otherwise there is no point. I am not really sure what equalpotent really means. I assume it means equal? In this case you have to make sure that elements in the powerset satisfy the relationship mRn such that m=n. In such cases the equivalent classes would just be {(a),(b),(c),(d)}
Sudo make me a sandwich
If I remember correctly you have to do something like
y1-y2 + x1-x2 = distance
then you match them to see if they’re the same. Otherwise it may be graphed and you have to show they’re at the same Y.
I don’t recall exactly how to do this.
Do you have a specific problem? That would help solve it & explain what we did and why we did it. Using abcd is less helpful. This is usually used when explaining a formula & any good reference will have at least 1 example.
In the USA, this is a commonly given equation for algebra, geometry & trigonometry.
To prove that equipotence (also called equinumerosity) is an equivalence relation, you need to prove that it is reflexive, symmetric, and transitive.
-For reflexivity, you need to show that A=A, which just means that an element is equal to itself.
-For symmetry, you need to show that A=B necessitates B=A, in other words that the order doesn't matter.
-For transitivity, you need to show that if A=B and B=C then A=C, in other words you can change the grouping.
To find the equivalence classes, you group the elements of a set into their own sets in which all the elements are equal. So, say, if you had the set [1,2,3,4,5] and you gave the equivalence relation that even numbers equal even numbers and odd numbers equal odd numbers, then you would partition it into [1,3,5] and [2,4].
I am not really sure what equipotent really means.
Equipotent means there's a 1:1 mapping, which really just requires that both sets have the same number of elements.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
I see. But op doesn't mention what the realstionship is so....???
No, it's discerete math, not algebra. The only algebra study in this area, at least in my school, is Boolean algebra which is totally different from x, y and z you learn in high school.
14 minutes ago, wasab said:
I see. But OP doesn't mention what the relationship is so....???
Yes he does, equipotence. He has to show that equipotence is an equivalence relation and find the equivalence classes for a particular power set under that relation.
I'd say it falls within abstract algebra, though I'm not particularly good with the categories.
I meant it’s commonly taught and given as a problem in algebra classes not that it is algebra. Bad phrasing on my part.
