So I have been building my gaming PC for the last couple of months, with a lot of help from my friends and videos I have seen. My current build is a MSI x370 gaming pro carbon MB, A8 9600 CPU, 16 GB Pacific Sun 2400MHz RAM, Thermaltake RGB 700W PSU, EVGA GTX 1060 6GB SSC, Patriot Burst 240GB SSD , and a WB 1TB HDD. I just recently bought a Ryzen 5 2600x to put into it, but when I do It simply will not post at all, no debug lights on the MB, nothing just a black screen. I have updated my Bios to the most recent version, and I have seen others use this board with this processor, I am still new to the PC building scene so if I missed anything, insight would be greatly appreciated.
https://linustechtips.com/topic/948110-2600x-wont-post/
After you update your BIOS do you revert it back to back to default settings and then pull the old CPU?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11537746
There should be a jumper on the mobo. If not just remove the coin cell battery and wait a few minutes
Main system: Ryzen 5 1600 | ASRock A320M | 8GB 2400MHz DDR4 RAM | GTX 1060 | 1TB WD BLUE
Server: AMD A6-7400K@4.3Ghz | 8GB 1866 DDR3 RAM | 2TB total storage
On the go: Thinkpad E440 | i5 4200M | 8GB DDR3 1600MHz | 500GB HDD
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11537773
When you're in your BIOS look for anything that looks like Load Optimized Defaults.
Actually, yeah. Just do this.
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11537776
Remove the battery with the new CPU, wait 1-2 minutes, insert it back in and pray for the silicon gods that your pc will post
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11537862
5 minutes ago, Timelancer said:
And I do this before I replace the old cpu correct? So I remove the battery, then wait a couple minutes. Do I boot up with old cpu or new at this point?
Do it after you've pulled the old CPU.
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11537874
I would say rma the cpu. If you know a computer shop that might test it four you, go ahead and ask if they can try it on other mobo/ram combination
https://linustechtips.com/topic/948110-2600x-wont-post/#findComment-11538401
