Does this help with gpu temps?
By
Guest
in Cooling
in Cooling
Solved by Guest,
6 minutes ago, Firewrath9 said:so the open air design means that the fans on the card are pushing towards the heatsink, not vice versa. if the fans on the gpu are pushing air towards your fans, thats not good.
I have decided that for now i wont add the bottom fans, but if the gpu gets too toasty i will consider it.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking0 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
