 hello everyone so a while back my computer just shut down and after that I keep having this someone told me it was my RAM so I bought the new one and send the old ones to repair but I keep having this and I don't know if it's my motherboard or my CPU can someone help me because I really don't know what's going on. Btw moederbord msi  970 gaming my CPU is FX-4300 AMD black edition
https://linustechtips.com/topic/948017-i-need-help/
its not finding an operating system, if you have an SSD then that probably unplugged itself or died
Builds:
https://linustechtips.com/topic/948017-i-need-help/#findComment-11537110
2 minutes ago, Paris77 said:
Oky  I'm going to try to add my back up SSD and see what it's gonna happen ?
 and thanks for the info
yah np, hope that solves it :)
Builds:
https://linustechtips.com/topic/948017-i-need-help/#findComment-11537124
I try with my working SSD and still get the same problems btw I forgot to mention I cannot get to my set up you know when you have to press F12 and you can go to the Bios and stuff I can't even see the logo anymore it automatically your sent me to this black screen :/ so I'm safe to say it's not my RAM or my SSD.
https://linustechtips.com/topic/948017-i-need-help/#findComment-11537157
