Ethernet Dead?
Solved by davehkiin,
Download something called Snappy Driver Installer Origin.
It's an open source software that searches for all drivers that your PC needs, and it's legit. Get rid of whatever that is.
https://www.snappy-driver-installer.org/download/
Download Application Only
Once you open it it will ask what you want to do, click Download Indexes
Let it download, it will find all the drivers
On the left you can click Select All then Download/Install
See if that helps.
