Hi guys,
I have an issue with my soundboard I hope you guys can help with. I use 3 things, voice meeter, exp soundboard, and vb-audio virtual cable. It works, but, my problem is the quality. When i play a song in exp (primary sound driver output enabled) so into my headphones, the sound is perfect. However, my friend told me that it sounds a bit like through a radio. I went into overwatch on 2 tabs, and listened to myself through the other account. It did sound considerably worse. On top of that, it cut out, like someone was carrying the sound source to and from the mic. You know when you're talking to someone and they move away and to the mic? like that. I have no clue how to fix it. Please help if you can. Another way i checked the quality; i opened up obs, and set the sound recording to voice meeter, so i can hear what my boi voice meeter does. When i watched it, i couldn't hear any difference. Only on the extreme dubstep sounds, which i also sped up, but the quality difference was so minor, that it might as well have been psychological, or the fact that the recording was louder. (Exp is set to 60% of normal volume in volume mixer). So i conclude there is probably some issue in overwatch? Help plssssssss
https://linustechtips.com/topic/947162-voicemeetersoundboard-issues/
16 hours ago, I is Rabbit said:
Hi guys,
Many game chat systems highly compress audio, this effect is exacerbated when sending in complex audio like a song. I use a soundboard that I send into game chat / discord and it's hit or miss depending on the game, even in discord the audio is compressed and converted to MONO.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
thx. rip lol
