Hello. I am doing a very large upgrade which consists of finally breaking free from my heavily upgraded pre-built pc. I'm getting a new motherboard, processor, ram, and case, but I need advice incase I'm doing something wrong. Here are the parts I'm getting:
APEX 21N-01 Mid Tower Case
Patriot Viper 4 3000 mhz 2 x 4 gb Ram
Biostar Z370GT6 Motherboard
Intel Core i5 8600k Processor
These are the parts I already have.
EVGA 500w Power Supply
1 TB HDD
EVGA GTX 1060 SC 3GB Graphics Card
Is there anything wrong with the parts I'm getting? As far as I know there aren't any compatibility issues.
https://linustechtips.com/topic/947068-advice-for-a-big-upgrade/
Take out that motherboard and replace it with an Asus Prime Z370-A
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
6 minutes ago, ZcanKal said:
the 8600k seems a bit overpowered for a 1060 3gb...
I would either upgrade the GPU (which you can't do, since you already have it) or downgrade the CPU to something like a lower tier Ryzen or an i5-8400
I play very cpu intensive games, so I don't need a graphics card to be powerful.
1 minute ago, Yehomilk said:
That's a $90 increase in price from what I'm getting, is it really worth it? What is better about the Z370-A than the Z370-P?
Okay then. Just buy any ATX Asus motherboard within your budget.
