any one here use dac Focusrite Scarlett 18i8 2 generation
https://us.focusrite.com/usb-audio-interfaces/scarlett-18i8
the red usb cable to the computer kinda short as i want big one i only saw a 10 feet one not sure there bigger and using different cable will it work perfectly even there label same brand of dac on the description of it?
any good brands of cables i could use to scarlet not sure is there differences of technology on there cables?
https://www.amazon.com/NiceTQ-Transfer-Focusrite-Scarlett-Interface/dp/B017J1OG16/ref=pd_ybh_a_10?_encoding=UTF8&psc=1&refRID=6Y2E22BKE3ZMMRGXT16V
https://linustechtips.com/topic/947000-audio-interface-cable-replacements-advice/
the cable that is included with the scarlett is just a normal USB B cable, nothing special.
just search on Amazon "USB B" and look for a decent cable, no it doesn't matter which cable you get, but also don't get a cheapo thin cable.. just get a decent one thats all.
https://www.amazon.com/AmazonBasics-USB-2-0-Cable-Male/dp/B00BCWALHM/ref=sr_1_2_sspa?ie=UTF8&qid=1531417188&sr=8-2-spons&keywords=USB+B&psc=1
this one seems pretty damn good to be honest.
Quote or Tag people so they know that you've replied.
USB 2.0 is rated up to 5 meters, there are even longer cables out there but you may run into some issues especially when working with an interface in which you want latency as low as possible. Any USB 2.0 B to USB A cable under 16ft should work fine:
StarTech 15-Feet USB 2.0 A to B Cable
If you needed something even longer you could use an "active" cable which repeats the signal to give you full bandwidth at a longer length:
Tripp Lite USB 2.0 Hi-Speed A/B Active Repeater Cable
Info about USB cable length:
http://www.yourcablestore.com/USB-Cable-Length-Limitations-And-How-To-Break-Them_ep_42-1.html
Edit: According to community guidelines you aren't suppose to use the share button on Amazon / shortened links. I have updated the post to contain appropriate links, apologies for the inconvenience.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
