Cooling Problems
QuoteThe room gets very hot and I even sweat when beside this pc after 2 hours of gaming.
I can relate lol
But... A S340 isn't going exactly to lower your temps, since, you know, it has a huge plastic panel covering the whole front and preventing the fans from sucking fresh air, yeah there's that tiny detail.
Sorry to burst the bubble but that case is kinda the type of stuff a ~60 yr old dad would buy to his teen son for xmas just because it "looks cool"
if you want some lower temps get a case with decent airflow or keep the cheap one you already have
about the fans, cheap ones work but are usually really noisy, get them if you don't mind that or you have headphones. my personal choice would be 2 front intakes and only the rear fan for exhaust, I'd look for a case with no top exhausts, a mesh front with no filters would be the ideal
something like this, sure it looks absolutely f*cking horrible but at the same time is able to keep cool an overclocked FX CPU and a 290x card under 85C at 100% load which is kind of a miracle considering the amount of heat that thing generates while playing a game
they don't make cases like that anymore
and what about this one
but that doesn't means isn't ready to game with an air cooled 7700k and a 780Ti SLI (friend's case)
you can't put good looks and decent airflow in a single case imo
