hi
i am hoping to get some help with  a build.
The budget is AUD $2000 is my max
the purpose of the computer is for creating virtual servers,rendering,3d modelling and gaming as well.
i currently have around 13, 3.5inch hdd so i have picked the w200 thermaltek as a suitable case.
since i have the storage and gpu already, i am looking for a motherboard, powersupply and ram for my machine.
i would like to have all the drives stored internally as i know that most motherboards wont support more then 6 or 8 i think.
After 16gb of memory with possiblity of expansion for future.
 W200  core thermaltek
Motherboard (needed)
Ram (needed )
Power Supply (needed)Processor have old i5 am willing to upgrade it if needed
Thanks if you took the time to read this
Feel free to shatter my dreams with reality
https://linustechtips.com/topic/946839-pc-build-help/
What parts do you already have specifically?
https://linustechtips.com/topic/946839-pc-build-help/#findComment-11526577
This is my best attempt at getting you something that will come close to what you desire. There is a SATA controller PCI/PCiE card to find still, more fans to budget for, and likely numerous other things that I have yet to account for.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor  ($458.00 @ Shopping Express)
CPU Cooler: Cooler Master - Hyper 212X 82.9 CFM CPU Cooler  ($48.00 @ IJK)
Motherboard: MSI - X470 GAMING PRO CARBON ATX AM4 Motherboard  ($269.00 @ Umart)
Memory: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory  ($239.00 @ JW Computers)
Case: Thermaltake - Core W200 ATX Full Tower Case  ($549.00 @ AX86 Gaming Systems)
Power Supply: Cougar - 1000W 80+ Bronze Certified ATX Power Supply  ($169.00 @ Umart)
Case Fan: ARCTIC - Arctic F14 PWM 77.3 CFM  140mm Fan  ($11.00 @ Skycomp Technology)
Total: $1908.00
Generated by PCPartPicker 2018-07-12 16:37 AEST+1000
Rawr.
https://linustechtips.com/topic/946839-pc-build-help/#findComment-11526650
I'm just using Newegg to pull up options for you, buy at your preferred retailer, or through amazon using the LTT affiliate link. Get at least 8GB dual channel kit, 16gb is better, but go with your budget as needed. That CPU is not as sensitive to ram speed, so I'd not spend extra money on a kit faster than 2400, but it's up to you.
Motherboard
extra SATA controller card
https://linustechtips.com/topic/946839-pc-build-help/#findComment-11526691
