Just play trial and error until you find the right set of pins for the connectors.
Had to do that with an older xps system last month. It sucks
Post a pic of the FP connectors on the old case.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
1 minute ago, kunka_boi161 said:
-pic snip-
I did see those, but they don't show a model number on the motherboard anywhere. Dell uses several major OEMs for it's motherboards and info can often be found from the motherboard manufacturer themselves, if you can find a model number.
well its a dell otiplexx 990 mini tower mother board. whats an OEM?
Whew, ok. An OEM is an Original Equipment Manufacturer. Dell doesn't manufacture, well, anything. I'm not even sure if they do any assembly in house anymore. Dell is just the company you bought the computer from, who has put together a computer package for you. The motherboards in them are actually manufactured by companies who specialize in electronics manufacturing, the OEM, like Asus, Foxconn, etc.
The company that manufactures the motherboard for Dell, the OEM, generally screen prints their name, a model number, a revision and some other information on the motherboard so that they can ensure nothing gets mis-matched anywhere along the process of making the motherboard or assembling the computer, and so that it can be replaced with an identical one if your computer needs to be serviced.
A google search of that model did come up with one motherboard with a massive front panel connection like that, but the model number on it an OEM only Foxconn board, so that's unfortunately not going to be helpful.
I would not try to hook up the LEDs at this point, as they have a positive and negative terminal, and installing it backwards, let alone on the wrong voltage, would quite simply kill them. For power and reset, start on the far left side of the connector, using pairs of pins on the top or the bottom row of pins(ie. 1&2 or 3&4) and work your way across no more than 3 sets of pins or you might get into audio or usb territory and possibly fry that controller on your motherboard by jumping pins. Plug the connector on, and press the switch. If nothing happens, try holding the switch for a few seconds. If neither of those does anything, those pins are not your power or reset. If taping it restarts the computer, there's reset. If tapping or holding it shuts the computer down, there's your power pins. If you do 3 sets of pins on the top row, and 3 sets on the bottom row and get nothing. It gets a whole lot more complicated from there.
15 minutes ago, kb5zue said:
Just curious, but did you take any notes or pics of the motherboard setup BEFORE you took everything apart to reassemble in the new case?  That information would have come in real handy when putting things back together.
tried taking a pic of the tower before taking it apart
Just figured out the power switch! now its just the hdd light and hd auido
I wouldn't really recommend doing LEDs, the likelihood of killing them is extremely high. HD Audio looks like it's right next to front panel, before a couple of USB headers, however the front panel connection on the motherboard doesn't look to be keyed to match a standard HD Audio plug.
the hd auido looks similar to the int usb but i only have one slot so i need to choose between the usb or hd audio
