So! Im Vanity and im currently buying a PC. I have my whole setup checked and you can check my posts for that! But anyway, I'm buying a keyboard ATM and these switches are messin with me. I know the differences between them but, I want to know which switches are best for Fortnite, CS:GO, and PUBG. I really know it's all down to preference but I'd appreciate any feedback! Thanks guys!
https://linustechtips.com/topic/946768-key-switches/
Ultimately it's personal preference, but it's well-regarded that Cherry MX Speed switches are the ones to choose for their short actuation, meaning you'll only need to press the switch a tiny bit for it to activate. It's crucial for quick reflexes in multiplayer competitive games.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/946768-key-switches/#findComment-11525915
Thanks for the feedback! I acknowledge the fact that it comes down to preference but any input is appreciated!
https://linustechtips.com/topic/946768-key-switches/#findComment-11525920
I personally think cherry mx browns are best for gaming because of their actuation point and force to push.
This is a really good guide for switches IMO: https://www.pcgamer.com/best-mechanical-switches-for-gaming/
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/946768-key-switches/#findComment-11525924
No problem! I actually use a keyboard with outemu blue (Cherry MX Blue clone, basically) switches for it's medium actuation and clicky tactileness. My future keyboard will be a Corsair Kxx RapidFire version for the speed switches, Cherry MX Speeds are going to be crazy to use.
https://linustechtips.com/topic/946768-key-switches/#findComment-11525926
Highly recommend you just youtube some videos. There's tons out there already on this subject.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/946768-key-switches/#findComment-11525982
It's subjective, but my personal opinion is that clicky switches are awful for gaming because of their large hysteresis making spamming slower and more difficult. Also linear switches are bad because it forces you to guess where the activation is. So I use exclusively tactile switches for gaming. If I only every did typing I could see myself using a super light linear switch like a Gateron Clear switch.
https://linustechtips.com/topic/946768-key-switches/#findComment-11526332
https://linustechtips.com/topic/946768-key-switches/#findComment-11528226
