Which 1440p 144Hz Monitors ?
(all PC part cost 45% more here,india)
1)Used AOC Agon Ag241QX (24'TN)  cost  350$
2)Used Asus MGW279Q (27'IPS) cost
545$
I don't know  if this Aoc monitor will  have good clour since its a TN panel
if I buy this Asus monitor my build will be for now
i5 8400
8gb ram
Gtx1070ti/80 or 1170
(if price is not above current 1080)
if I go with the TN 24inch aoc I probably  could get
1)Used i5 8600k
2) 240gb ssd(i can deal with  using hdd)
3)2Tb hdd (which is not immediately  needed)
And a better case maybe which is my last priority unless it gives me more performance (cooling)
Please help me
I'm from poor country
Things cost 45% more
I'm going to used up all my money on this xD
I'm hesitant with the aoc build because  I love beautiful picture/video. I'm not sure if I will regret it. Thank you all
https://linustechtips.com/topic/946493-need-help-building-pc/
If money is tight, maybe get a used system. Haswell stuff like an i7 4770 goes well with modern graphics cards. TN panel is a bit of a shame to use with a good gaming computer, so it might be good to save on the CPU to get a nice display. 8GB of ram and an SSD is a great place to start. Any modern graphics card does well with slightly old CPUs.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11522990
22 minutes ago, Chhana said:
It sounds like you should be just buying a cheaper 1080p 144hz display with a GTX 1060 6GB or RX 580
and possibly a cheaper R5 1600 with an ASrock Pro4 depending on pricing.
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11523011
-Moved to New Builds and Planning-
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11523029
Actually I have never seen a tn panel
Or a1440p,4k monitor
Or a high refresh rate monitor
I just watch lots of techtuber Vids haha
Is there such a difference  between  1080p and 1440p resolution
Guess I'm better off with cheaper monitor and used it for a 2 3 yrs  and got monitor upgrade and hope fully a fully capable  4k got :) thanks all
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11523046
11 minutes ago, Chhana said:
What do you guys think of the AOC Agon Ag241QX costing just abit more  than the currently used 1080p 144hz monitor I have found . I think even some techtuberu used it(no as big as Linus lol)
That monitor is going to be fine, but if money is an issue you're better off with a cheaper 1080p 144hz display most likely.
http://gadgetynews.com/aoc-agon-ag241qx-free-sync-gaming-monitor-review/
But if you're buying a free-sync display go for an RX 580 8GB or Vega 56, although last I looked in india they cost way more than the nvidia cards for some reason.
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11523057
8 hours ago, Streetguru said:
Vega  is too unreasonable  pricey here.
 Using B310 mobo instead of Z370 will save me 240gb Ssd plus some cash
I know mootherboard doesn't  affect
much performance  but how about in my build?  I mean I will be using 1070ti/80...
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11524239
3 hours ago, Chhana said:
What's the pricing on Ryzen compared to Coffee Lake?
You probably want a B360 board at minimum, and one that has VRM heatsinks.
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11525050
R5 2600  cost 30$more than 8400(new)
But the i5 8400 I'm buying is 60$less
in one techtube channel 'UFD tech' he's claiming that i5 8400 performs worse than 2400,2600 on a non Z370board . This had me concert
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11526901
24 minutes ago, Chhana said:
Unless it's like a really shitty board, with single channel memory it's probably not slower on average.
But I'd just go for Ryzen, extra threads may be useful to you are some point, over maybe 15-20 more fps on average. Can use a B350 board with an updated bios without issue. Or just any X470 board will be fine.
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11526965
Speaking of Ryzen.. Could you please give me a build guide for budget adobe premiere  pro rig. It's for my friend.  I know Ruben is good for productivity.
Will recomending r5 1600x good? (x ver. Cost 1dollar more)
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11527413
You want Coffee Lake for Premiere, probably an i7 8700, due to a recent Intel Quick Sync update. Or just use Vegas and save money anyways
Ryzen will be fine for premiere, coffee lake just might be faster. Although if he's doing handbrake encoding as well, or wants to game while rendering, ryzen might be worth it then.
https://linustechtips.com/topic/946493-need-help-building-pc/#findComment-11528552
