Alrighty, so I don't know if anyone else has done this yet or bothered to make a post about it but here is my take on a drain loop in an aluminum water cooling system. So what I've done is I have found a mixture of acrylic parts that I think will be compatible with all of the EK Fluid Gaming fittings and will allow me to create a drain loop. This included finding an acrylic splitter, an acrylic female to female extension, and acrylic G1/4 plugs. The parts are all pretty self explanatory, but any questions you have I should be able to answer. To visualize the solution I made a quick sketch in my notebook that I've attached below. The link to all the parts as well as my next phase in my computer build is here.
Any other questions or comments just @Hyp3rion and I'll try to reply.
Tot gauw
https://linustechtips.com/topic/946449-ek-fluid-gaming-drain-loop/
1 hour ago, Dreaper said:
I would just put a t block off a port towards the bottom of the loop then when you need to drain attach some soft tube in a bucket.
Thought of that but couldn't find any acrylic or aluminum ones that seemed to fit my needs.
Tot gauw
1 hour ago, Hyp3rion said:
-SNIP-
It's not ideal since you will have a dead zone of fluid with very little flow, that area will collect junk potentially over time. You can easily use two sets of quick disconnects as a drain inline to your loop. One that is integrated inline and a second set you simply have on hand to attach and drain the loop with.
https://www.ekwb.com/shop/ek-qdc-10mm-gray
1 hour ago, W-L said:
quick disconnects
Thanks for that. I had been looking for something like that that would work and couldn't find one. Guess I was looking in the wrong places or didn't notice it at first.
Tot gauw
