Hi all,
So my graphics card is an Asus ROG Strix GeForce GTX 1070 8GB OC and i'm having some problems while playing some games.
It started a couple of weeks ago and this is what happens https://imgur.com/a/gvnwgpE
Then i downloaded FurMark Rog Edition stress test and it lasted only a minute until it froze like the picture.
Next i take the 1070 to a friends house, install on his pc, run the same stress test thinking that it would freeze after 1 minute but no, it goes for over an hour.
So maybe the the GPU is fine? i do some online digging and someone tells me that maybe the problem is with my PSU, that would explain why it worked on my friends pc and why it only freezes on heavy graphics games.
Next i take my pc to my friends house, try his PSU on my PC, do the same stress test, and also freezes after around 1min, tried Rise of the tomb raider maxed out, freezes after 1min.
Tried lowering the GPU boost clock and it still froze.
Dont know what else to try. I have latest drivers, i even did a clean windows install and same thing happens.
This is what shows up in the event viewer:
Can not find the description of Event ID 13 from the source nvlddmkm. The component that triggers this event is not installed on the local computer or the installation is damaged. You can install or repair the component on the local computer.
If the event originated on another computer, the presentation information must be saved with the event.
\Device\Video3
CMDre 00000001 000000c0 ff1fe205 00000007 00000000
\Device\Video3
Graphics Exception: ESR 0x405848=0x80000000
\Device\Video3
Graphics Exception: Shader Program Header 1 Error
\Device\Video3
Graphics Exception: Shader Program Header 2 Error
\Device\Video3
Graphics Exception: Shader Program Header 3 Error
\Device\Video3
Graphics Exception: Shader Program Header 4 Error
\Device\Video3
Graphics Exception: Shader Program Header 9 Error
\Device\Video3
Graphics Exception: Shader Program Header 18 Error
\Device\Video3
Graphics Exception: ESR 0x405840=0xa204021e
\Device\Video3
0ac0(2f10) 00000000 00000000
My specs
CPU: Intel Core i5-6600K
MB: Asus Z170-A
RAM: 16323 MB (DDR4-2133 DDR4 SDRAM)
GPU: Asus ROG Strix GeForce GTX 1070 8GB OC
PSU: Corsair RM850
2 SSD's and 1 SATA
Friend specs
CPU: Intel Core i5-2500K
MB: Asus P8P67 PRO (rev 3.1)
RAM: 8 GB
PSU: NOX Sonar 780
Dont know if its a problem with my GPU or something else, since it worked fine on my friends pc.
Sorry for long text and any grammar mistake.
https://linustechtips.com/topic/945248-graphics-card-problem/
when i install new hardware, what works for me is re-installing windows ast it only takes about 20 minutes if that, Noty saying this is a fix but parts are happier with frsh installs and their new.
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
https://linustechtips.com/topic/945248-graphics-card-problem/#findComment-11511739
10 minutes ago, brokeviski said:
Well that might have solved it, did the downclock and seems stable for now. But now what? is the card broken? should i activate its warranty?
Yea, send it for an RMA. That is a faulty VRAM that does not run stable according to its specs.
https://linustechtips.com/topic/945248-graphics-card-problem/#findComment-11512329
