x has higher base and xfr (think turbo boost but amd) and slightly better binning iirc for overclocking
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
2 minutes ago, zoodoo123 said:
whats the difference between a ryzen 5 1600x cpu and a ryzen 1600 cpu.
The 1600's default frequency is 3.2 GHz and the 1600X's default frequency is 3.6 GHz. If you overclock, there's no difference.
Aside from default clocks, older 1600 were binned worse (i.e. overclocked worse) than 1600x and later produced 1600.
Desktop benching:
