DT990 premium 250 ohm VS dt990 pro
Jnys
Ok now end my confusion. Which are the best for gaming The dt990 pro 250 ohm or the dt990 premium 250 ohm And remeber these are for gaming.
Sound wise they're same, except what little 25% higher head band clamping force of Pro might cause by compressing ear pads more.
Headband inside cushion is spring steel so it wouldn't mind bending to loosen it.
Also if connector is near Pro's coiled cable could work better, while straight 3m cable needs more managing to keep it from dropping to floot, where it could get damaged.
But if connector is in rear of PC then coiled cable would likely need some extension.
so i have a pretty small head so wich will fit best?
imo they are not comfortable (dt 990 pro)
so the premium is good for gaming?
So the premium dt 990 is comfortable
Have you auditioned the DT990 yourself? Do you know what kind of sound you want? Do you have a problem with sparkly treble? I have a DT990 600Ohm Premium and it's an old one, so I find the clamp force to be just right, it doesn't clamp hard on my noggin, but is tight enough to hold the can onto my head even if I were to move about. My DT770 Pro is a tad tighter so there is a little discomfort, but nothing to write home about.
The DT990 600Ohm Premium I have has a rather sparkly treble, so if you get irritated with brighter sounding cans, the DT990 isn't for you. I love mine as I find the sound to be dynamic, sparkly highs, neutral'ish mids with a mild bass boost, what's not to like? I'm something of a treblehead, so I like brighter sounding cans....
Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
