I recently built a gaming pc specs below
Whin i boost to windows i can only access to nvidia gpu drive but i cant See intel uhd graphics 630 why?
Specs
Graphics card : GTX 1060 3GB
CPU : I7 8700
SSD: ADATA 256GB
Motherboard : MSI z370-a pro
RAM : Geil evo potenza 1x8gb 2400mhz
PSU : COOLER MASTER NWE 80+ BRONZE 550W
Case :Shapkoon S25-W
Keyboard : unknown
Mouse: Razer Lancehead tournament edition white
https://linustechtips.com/topic/944356-i7-8700-intergrated-graphics-problem/
Because the integrated graphics are disabled if you connect a gpu. You can enable it in bios, but as your monitor is still connected to your main gpu, you can only use it for quicksync video.
If you for some strange reason want to use the integrated graphics, put the video cable into the motherboard hdmi port instead of the gpu's.
Check your motherboard BIOS to see if there is an option to use both. On many motherboards, once a discrete graphics card is detected, the on-board graphics are automatically disabled.
The iGPU can be made useful. It's good for extra video outputs, for instance, and has some features you can use such as Quicksync, which greatly speeds up video encoding in those programs that support it.
