HELP - Thermal paste and copper shim?
Solved by Christophe Corazza,
5 minutes ago, Phantomx60 said:Thanks for the response, I was thinking something similar, I'll take your advice and stick to only applying thermal paste. I've seen Arctic MX-4 mentioned here a good number of times, it looks decent and pretty cheap, so I'm going to order that.
Arctic MX-4 is indeed a perfect budget-wise thermal paste that is excellent for every day use.
One step up the ladder, you can find Noctua NT-H1 and Arctic Silver 5. Both are very good thermal pasts and perform well for overclocking.
If you really want to go balls to the walls in terms of performance, you could buy Thermal Grizzly Kryonaut which is obviously more expensive than the previous ones. However, in your case this would simply be overkill ;-)
