is that ice?
try wet your finger (no dripping water) and smear some water on the blurred area. If it becomes clear, then that's just the surface to the monitor being scratched horribly. you can use some fine sand paper to make the surface more smooth so it looks better.
Desktop benching:
https://linustechtips.com/topic/943835-help-me-fix-this/#findComment-11498914
4 minutes ago, wihi48 said:
I guess I can do that but I'm pretty sure there will still be that white thing on the screen (1st pic)
I tried using clear nail polish to fix a scratched phone screen, but that's a risky thing to do and makes the screen glare very noticeable. Not a perfect fix either, but I'm no professional so I didnt have much expectation anyway
Desktop benching:
https://linustechtips.com/topic/943835-help-me-fix-this/#findComment-11498946
