My current build is as follows:
CPU: Ryzen 5 1600 @3.2ghz, using stock Wraith cooler
RAM: 2x8gb 2667 DDR4
GPU: RX 560 (Will be upgraded to 1070ti or 1080 in about a month)
PSU: 650W Gold rated Corsair modular supply (idk exact model)
Rest of the build doesn't matter much for performance, I'm pretty sure.
My question is this: My next upgrade will be the CPU/Motherboard, so what upgrades would people recommend assuming I game at 1440p and record/stream at 1080p? Currently I'm looking at the i7-8700K and the R7-2700X. Either way I'd be buying a new motherboard and cpu cooler. However, as far as I can tell, the i5-8600K would accomplish the same thing as the i7. Is the extra speed really that important? Help is always appreciated!
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/943780-picking-a-processor-for-streamingrecording/
Intel would probably be the best.
Choose the 2700X or 8600k, doesn't significantly matter.
However if you're editing (especially with the adobe suite), the intel i7 will make it a lot nicer for you.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
Overclock the 1600 first before considering an upgrade. Might as well go as far as replacing the stock cooler, but definitely give the 1600 a chance.
Desktop benching:
I actually do some editing as well, that's good info.
That's a good idea. How long do you think I could go before needing an upgrade?
Current Desktop:
