I am VERY close to finishing my water cooling loop shopping list, and all I need are some reservoirs. I am looking at the Reservoirs for $26 on amazon (Link Below). This seems like it may be a bit sketchy, being that it is only $26 for 180mm... Does anyone know if these are safe to buy? I don't wanna deal with having to return them if they suck, and it could possibly leak on my pc parts. Thanks in advance. https://www.amazon.com/Maximized-Compatibility-Reservoir-P-LOTOR-Heat-resistant/dp/B0793MTFZF/ref=sr_1_3?ie=UTF8&qid=1530507999&sr=8-3&keywords=water+cooling++reservoir
https://linustechtips.com/topic/943484-watercooling-help/
That looks like it will work but very off brand let's say. I would really recommend to get good quality components for watercooling to ensure your have a reliable and safe loop. If you are looking for more cost effective components Barrow isn't a bad choice.
https://www.amazon.com/Barrow-Reservoir-Acrylic-220mm-Black/dp/B01MQ3GNHW/ref=sr_1_1?ie=UTF8&qid=1530508682&sr=8-1
https://linustechtips.com/topic/943484-watercooling-help/#findComment-11495444
thank you. I didnt see this. I do want something a little bigger than 180mm anyway
https://linustechtips.com/topic/943484-watercooling-help/#findComment-11495446
$400 isn't really much for a loop. But they have good res's there for not much. Assuming you are going for looks with a tube res.
https://linustechtips.com/topic/943484-watercooling-help/#findComment-11498103
