Heatsink Replacement
Solved by Jurrunio,
1. Does it interfere with your RAM sticks. As long as the heat spreader on the sticks arent that tall like RGB sticks common today, it's fine.
2. Is it too tall for the case. Otherwise you wont be able to close the side panel (not critical, since a PC can run without a side panel).
_Darasuum_ ·
Posted in Power Supplies4 -
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting4 -
Ozzi ·
Posted in Networking5 -
3
play_circle_filled
Latest From ShortCircuit:
