Posted June 30, 2018 I have heard great things about the I5 8600K but it is a bit out of my budget, wondering if i should go for an I5 7600K or a Ryzen 7 2700x. Any other suggestions? Leave them below please Link to comment https://linustechtips.com/topic/942849-cpu-questions/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 30, 2018 Solution 2700x, all the way. Quote or tag me( @Crunchy Dragon) if you want me to see your reply If a post solved your problem/answered your question, please consider marking it as "solved" Community Standards // Join Floatplane! Link to comment https://linustechtips.com/topic/942849-cpu-questions/#findComment-11490092 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 30, 2018 Go for the 2700X of course. Although the i5 has a slightly faster single core speed, in overall tasks the 8 cores 16 threads of the 2700X easily beat the mere 4 cores 8 threads of the 7600K. Link to comment https://linustechtips.com/topic/942849-cpu-questions/#findComment-11490101 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 30, 2018 While 7600k's higher single core performance can help it beat Ryzen 7 in older games in which single core performance means everything, new games benefit from the extra core count so much, the higher clock speed isnt enough to justify buying the 7600k. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/942849-cpu-questions/#findComment-11490104 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 30, 2018 Author Thanks guys Link to comment https://linustechtips.com/topic/942849-cpu-questions/#findComment-11490371 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
