Hello i have been dealing with this problem for months now, and cant find any solution to it. My PC is running very poorly with high input lag, lower fps then before and CPU usage 90%-100% in all games. My CPU temperatures are fine (30-45 degrees).
Games are pretty much unplayable because of the lag
Things i have tried -
Re seating parts and CPU Fan
Doing a full re install of windows (this indicates to me that it is probably a hardware issue)
Tried different power outlets
Tried different power board
Clean the CPU and other part sockets and dusted PC
Tried it with a different hard drive
Tried it in another house
Specs -
GPU - GTX 1060 6gb
CPU - Intel i5 7600K
Ram - 16GB DDR4
Mobo - Z270
Any help or suggestions of any kind would be really appreciated because I am so frustrated with this.
https://linustechtips.com/topic/942831-cpu-high-usage-low-fps-high-input-lag/
I have tired linux?
You can run some benchmark/games in linux and see if the problem persist. I have found my laptop rarely fan ramp on my laptop compare to windows. Window seems like to randomly use cpu when just watching a video.
See if the problems persist on linux, it could be just windows drivers.
Magical Pineapples
3 minutes ago, MrUnknownEMC said:
I have tired linux?
Thanks for the suggestion
7 minutes ago, Rainbow Dash said:
What type of RAM do you have? Also what speed does it show in CPUz for memory speed? If you can, screenshot CPUz.
I have 2 8GB sticks of G.Skill Ripjaws, dont have CPUz but can download it if you would like.
3 minutes ago, Halbo said:
Your RAM looks fine. Do you have Windows on power saving mode? Considering you have tried a different PSU. So have you checked what uses 100% of the CPU during gaming with Task Manager?
Haven’t tried a different PSU, only a different hard drive. Don’t have windows on power saving mode and generally it’s the game that puts it to 100%
1 minute ago, AskTJ said:
I think the ram is in single channel mode. Could you take a photo of how you inserted your ram? @Halbo
It is in single channel mode because one of the ram slots is broken on the motherboard, however this problem outdates that one so I know that is unrelated and not a factor.
Do you have 4 slots, or 2 slots on your board?
hi.
