So i have had this issue of what i would describe as screen tearing but it isn't as a far as i know. the lines will move up and down my screen when moving my mouse left and right, as far as i have noticed it only happens in games, no tears on UFO Screen Tear tester or youtube videos, have had it happen since Win 10 update 1803 but cant be exactly sure, it happened with my old pc (Specs below) so i assumed build a new pc (Specs Below) with every part bought brand new and the issue would be gone, was i wrong.
Here is a video of my problem, i have capped my monitor at 60hz and the fps at 60 to properly show the issue, as at 144hz 144fps my phone does not pick it up so well: https://youtu.be/w1OvRqe9iHw  -- this is a video of it being captured through fraps, the tear cant be seen: https://youtu.be/nGvs3S5emAo
pc specs (Old)
i7 6700k
Msi 980ti
G1 Gaming Mobo
Samsung 250 Evo SSD
WD Black 1tb HDD
G.Skill Tridend Z RAM 16gb 3000mhz
XFX Black Edition 850W
Windows 10 Pro
pc specs (New)
i7 8700k
EVGA 1070
Rog Strix z370-f gaming mobo
Avexit RAM 16gb 3000mhz
Samsung Evo 250gb
WD Black 1tb HDD
Corsair Gold 750W
Windows 10 Pro
Things i have tried:
As stated a brand new pc build, a better build at that, so i can rule out my hardware.
Also tried 3 different EVGA 1070's, a MSI 980ti and a Strix 1080 (a friend of mine builds pc's hence access to parts, he has also never seen this issue)
Tried 3 Monitors, Acer Predator GN246HLB 144hz, Acer Predator X34P Gsync Enabled still "Tearing" and a Benq RL55HM 60hz. all tried using DisplayPort, HDMI and DVI-Dual Link on each.
Setting different refresh rates/fps, this either reduces or increases how noticeable it is depending on the game, some games the line is just a very fast moving single line rather than the lines in the video above.
Have tried Low-Ultra settings in game, make no difference on what settings i use.
My temps are always below 70, EVGA 1070 usually around 60-65, i7 8700K usually around 60-70.
Can confirm enabling Vsync/Fast sync fixes it for some games but have never had to use it in the past it has always been fine, its a recent issue im having.
If anyone has any help or know/seen anyone having the same issue please leave some feedback as i don't know what else i can do at this point. thanks for reading.
https://linustechtips.com/topic/942265-screen-tearing-like-issue-help/
