300 is very low. Might have to do Used parts.
Budget:
$300
Doing any Gaming:
What do you mean For youtube?
Like watching Videos?!
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/942183-plan-build-1337/#findComment-11483546
Budget:
$300
Doing any Gaming:
Know what actually, mostly low-stream gaming. CSGO and what not.
Updated budget too.
https://linustechtips.com/topic/942183-plan-build-1337/#findComment-11483549
need os/monitor/peripherals? just games like CS:GO or with AAA games?
https://linustechtips.com/topic/942183-plan-build-1337/#findComment-11483552
Updated budget too.
https://pcpartpicker.com/list/7Tz4gw Idk if you can stream with this but it can game at medium/low settings.
You might wanna check out this video
Its a used xeon that can game for only 16 bucks
Motherboards for that xeon are usually pretty cheap
https://linustechtips.com/topic/942183-plan-build-1337/#findComment-11483553
